Xannaxx
Newbie level 1
Hi all,
I am doing my project and trying the gate charge simulation of Trench power MOSFET (UMOSFET).
According to the examples in this software, I changed parameters to meet my requests but after I click the 'Run'
the program runs and runs and runs.... run forever
I have no idea what is going on and really hope you can help me out
I gonna really appreciate for any help
Here is my code profile
# (c) Silvaco Inc., 2015
go devedit
DevEdit version=2.4.2.R
work.area x1=0 y1=-0.5 x2=3 y2=17
# devedit 2.4.2.R (Wed Oct 29 20:04:11 PST 1997)
# libsflm 2.0.0.R (Thu May 1 18:03:38 PD1T 1997)
# libDW_Misc 1.20.0.R (Mon Apr 28 17:55:25 PDT 1997)
# libCardDeck 1.20.0.R (Tue Apr 29 15:01:54 PDT 1997)
# libGeometry 1.20.0.R (Mon Apr 28 18:17:55 PDT 1997)
# libDW_Set 1.20.0.R (Mon Apr 28 17:57:52 PDT 1997)cc c vc vc
# libSVC_Misc 1.20.0.R (Mon Apr 28 18:20:53 PDT 1997)
# libSDB 1.0.6.C (Mon May 5 16:28:49 PDT 1997)
# libSSS 1.20.0.R (Mon May 5 16:29:45 PDT 1997)
# libMeshBuild 1.20.2.R (Wed Oct 15 20:34:28 PDT 1997)
# libDW_Make 1.1.3.R (Thu May 1 20:07:31 PDT 1997)
region reg=1 name=n+sub mat=Silicon color=0x7f00ff pattern=0x8 \
polygon="2.5,3.7 2.5,4.7 0,4.7 0,3.7"
impurity id=1 region.id=1 imp=Arsenic \
peak.value=1e+19 ref.value=1000000000000 comb.func=Multiply
constr.mesh region=1 default
region reg=2 name=n-drift mat=Silicon color=0x7f00ff pattern=0x8 \
polygon="0,3.7 0,1.5 1.98,1.5 1.98,2.02 2.5,2.02 2.5,3.7"
impurity id=1 region.id=2 imp=Arsenic \
peak.value=2.76e+17 ref.value=1000000000000 comb.func=Multiply
constr.mesh region=2 default
region reg=3 name=pbase mat=Silicon color=0x7f00ff pattern=0x8 \
polygon="0,0 0.5,0 0.5,0.5 1.98,0.5 1.98,1.5 0,1.5"
impurity id=1 region.id=3 imp=Boron \
peak.value=0.84e+17 ref.value=1000000000000 comb.func=Multiply
constr.mesh region=3 default max.height=0.25
region reg=4 name=n+source mat=Silicon color=0x7f00ff pattern=0x8 \
polygon="0.5,0 1,0 1.98,0 1.98,0.5 0.5,0.5"
impurity id=1 region.id=4 imp=Arsenic \
peak.value=1e+18 ref.value=1000000000000 comb.func=Multiply
constr.mesh region=4 default max.height=0.2 max.width=0.25
region reg=5 name=gateox mat="Silicon Oxide" color=0xff pattern=0x2 \
polygon="2,2 2.5,2 2.5,2.02 1.98,2.02 1.98,1.5 1.98,0.8 1.98,0 2,0"
constr.mesh region=5 default
region reg=6 name=gate mat=PolySilicon elec.id=1 work.func=0 color=0xffff00 pattern=0x5 \
polygon="2,0 2.5,0 2.5,2 2,2"
constr.mesh region=6 default
region reg=7 name=source mat=Aluminum elec.id=2 work.func=0 color=0xffc8c8 pattern=0x7 \
polygon="0,0 0,-0.5 1,-0.5 1,0"
constr.mesh region=7 default
substrate name="drain" electrode=3 workfunction=0
# Set Meshing Parameters
base.mesh height=2 width=0.5
bound.cond !apply max.slope=30 max.ratio=100 rnd.unit=0.001 line.straightening=1 align.points when=automatic
imp.refine imp="Net Doping" scale=log transition=1e+10
imp.refine min.spacing=0.02
constr.mesh max.angle=90 max.ratio=300 max.height=1000 \
max.width=1000 min.height=0.0001 min.width=0.0001
constr.mesh type=Semiconductor default
constr.mesh type=Insulator default
constr.mesh type=Metal default
constr.mesh type=Other default
constr.mesh id=1 under.mat=PolySilicon depth=0.1 default max.height=0.02 max.width=0.2
constr.mesh id=2 x1=4.9 y1=0 x2=5 y2=3.5 default max.width=0.02
constr.mesh id=3 x1=0 y1=2 x2=5 y2=3.5 default max.height=0.1
constr.mesh id=4 x1=0 y1=10 x2=6 y2=12 default max.height=0.4
constr.mesh id=5 x1=5 y1=0 x2=5.15 y2=3.5 default max.width=0.02
Mesh Mode=MeshBuild
bound.cond !apply max.slope=30 max.ratio=100 rnd.unit=0.001 line.straightening=1 align.Points when=automatic
struct outf=powerex11_0.str
tonyplot powerex11_0.str -set powerex11_0.set
go devedit
DevEdit version=2.4.0.R
init infile=powerex11_0.str
# devedit 2.4.0.R (Thu May 8 12:10:27 PDT 1997)
# libsflm 2.0.0.R (Thu May 1 18:03:38 PDT 1997)
# libMeshBuild 1.20.0.R (Wed May 7 23:57:48 PDT 1997)
base.mesh height=1 width=2
imp.refine imp="Net Doping" scale=log transition=1e+10 sensitivity=2
imp.refine min.spacing=0.2
constr.mesh max.angle=90 max.ratio=300 max.height=10000 \
max.width=10000 min.height=0.0001 min.width=0.0001
constr.mesh id=1 x1=2.5 y1=0 x2=1e+06 y2=0.5 default max.height=0.1 max.width=2
constr.mesh id=2 x1=2 y1=0 x2=4.5 y2=0.5 default max.height=0.1 max.width=0.2
Mesh Mode=MeshBuild
refine mode=y x1=0.15 y1=5.98 x2=9.82 y2=7.53
base.mesh height=1 width=1
structure outf=powerex11_1.str
go atlas
# This example demonstrates gate charge characteristics of a DMOS structure.
# SPISCES, MIXEDMODE was used
# Part 1: Steady state solution
# Circuit descriptions
.begin
iin 0 1 0
r1 1 0 1e6
amos 1=gate 2=drain 0=source infile=powerex11_1.str width=1e4
iout 0 2 0
ddum 2 3 ideal
vin 3 0 0
# End of circuit description
.model ideal d()
.nodeset v(1)=0 v(2)=0 v(3)=0
.numeric lte=0.05
.options fulln print
.save outfile=powerex11
.log outfile=powerex11
.dc iout 0 1e-9 0.1e-9
.dc iout 1e-9 1e-8 1e-9
.dc iout 1e-8 1e-7 1e-8
.dc iout 1e-7 1e-6 1e-7
.dc iout 1e-6 1e-5 1e-6
.dc iout 1e-5 1e-4 1e-5
.dc vin 0 20 0.2
.end
contact device=amos name=gate n.poly
interface device=amos qf=2e11
models device=amos conmob fldmob surfmob srh auger bgn print
impact device=amos selb
method newton autonr trap
go atlas
# Part 2: Transient Solution
.begin
iin 0 1 0 pulse 0 1e-5 1e-10 1e-10 1e-10 100e-1 200e-1
r1 1 0 1e6
iout 0 2 1e-4
ddum 2 3 ideal
vin 3 0 20
.model ideal d()
.numeric vchange=0.01 imaxtr=50
.load infile=powerex11
.save outfile=powerex11_tr
.tran 100ps 30e-1
.end
go atlas
tonyplot powerex11_tr.log -set powerex11_1.set
quit
