piyushpandey
Member level 4
hello guys
I want to ask one very basic thing which I have encountered many times during circuit studies and that is the significance of the high resistance in the circuit.
Actually I want to know that how a voltage is sensed across a circuit if there is no flow of current , for example in the figure below:
In this figure it is written that The value of the output pull-up resistor must be high enough to avoid excessive power dissipation, and yet low enough to allow adequate supply to switch the load circuitry being driven by the output. Now what I want to know is that if the value of the resistor is in the megaohms range than will it allow the current to flow through it and if not than how come the voltage is sensed across the output without the flow of current for example in the case of the voltage divider.
Also if the current flow is zero in the above diagram than it is beneficial for the above comparator because it will not be loaded by the incoming circuit as the load and the bias condition and the voltage supply to the comparatoir will not be effected.
and if there is current flow than is there any value of resistance for which the current is zero and the voltage is equal to the no load or terminal voltage across the output.
also I want to know that how is it possible to realize the voltage with no current flow across the circuit with the use of high value resistances , and can it be realized without the use of the high value resistances.
Thank you
Thank you
