signal integrity in Cadence allegro
jack_pcb
Member level 3
Member level 3
Hi all ,
I am a pcb designer , learning SI .
Can anyone help about SI by using cadence allegro .
PLs tell the steps for SI in Allegro .For SI , i should use SigXplorer or the PCB SI ?
Pls help with some Docs to understand .
Thanks
Hi Jack
it depends on what simulation you need to do. Is it pre or post simulation. if you have the tool installed in your PC, you can directly use the tutorials. all the best
hi ,
thanks for the reply .
I hav tool installed. but for pre layout and post layout which one is used and any help doc pls
thanks
