ku637
Hello,
Im new to Signal Integrity analysis , but i have a doubt regarding the suppply voltage ranges used inside an IBIS model
An IBIS Model as i understand includes slow weak,fast and typical corner behaviour of the chip
I see in a typical IBIS Model for an IC
| Variables typ min max
[Pullup Reference] 3.3 2.97 3.6
[Temperature Range] 25 125 -40
[Voltage Range] 3.3 2.97 3.6
So while running the simulation in different corners im seeing the output voltage steady levels at these voltages.
So i see for a different IBIS model this voltage range will be different
So incase of a driver and reciever , it looks like there will be difference in the voltage steady states
But my question is in a single PCB we have a single 3.3V which may supply to driver and as well as to receiver, the tolerance for that voltage is say 3%. In that case does this model defintion is reasonable , to increase accuracy do we need to edit the driver and receiver voltage ranges to 3% of 3.3V . Is that acceptable.
