sigma delta adc in cadence spectre
Firas
Junior Member level 3
snr calculation in cadence
Hello friends,
I'm working on a second order switched capacitors sigma-delta modulator,
I want to calculate the SNR of the modulated signal (output of the modulator),
Please can anyone help me how to calculate the SNR of this signal with the calculator of CADENCE,
Thanks in advance.
snr cadence
I do not know how to calculate SNR with cadence.
But in my case, I simulated & extracted data (0,1,0,1,1......) and calculated SNR with MATLAB.
If you want, I can send you my code.
snr cadence calcualte
Hello ljy4468
I have find many code that calculate the SNR with MATLAB, but everyone give me a different result compared to others, and I don't know what is the best one.
Please can you send me your code.
Thanks.
Added after 2 hours 11 minutes:
Here's how I do it:
[url]https://www.circuitdesign.info/2008/09/calculation-of-adc-snr-in-cadence-skillocean/[/url]
P.S. I also dump to Matlab for an FFT. However, I do compute the SNR/SNDR using Cadence Ocean/Skill.
Hello PoojanWagh
I don't find the code of "matpsd" procedure in this skill/ocean code,
please can you send me the code of this procedure,
Thanks.
snr in cadence
Ok here it is.
Matlab code & example extracted file.
Hope it can help you.
Regards
    Firas
calculate snr in matlab
Hello ljy4468
Thank you for your help.
When I run this code, an error come out at the line 15 because the function calculateSNR.m is not found.
??? Undefined command/function 'calculateSNR'.
Error in ==> sdmcal at 15
snr_=calculateSNR(spec(1:ceil(N/(2*OSR))),tone_bin);
Please can you send me the code of this function.
And please can you explain to me what is the variable tone_bin.
Thanks.
Thanks for these Matlab files. I was looking for these files to calculate SNR of my Sigma delta ADC.
When I simulate this file I have an error,
"??? Undefined function or method 'calcSNR' for input arguments of type 'double'."
Function calcSNR is not defined..Can you please help me.
Thank you
