shut down supply voltage comparator
yassin.kraouch
Advanced Member level 2
i have an external battery ( 12V) that supply a developpement board throught a DC-DC converter, i want that if the voltage of the battery is below 12V i force DC-DC chip to not work, have you an idea about this ?
you need to have an another reference(low power, commercial battery) and to compare it with your battery and then drive a MOS transistor to shut down the supply of the development board.
Or to use a chip with a shutdown integrated.
Hope it helps you.
joseMiguel
is there any method to be used in without shut a reference ?
You need a voltage monitor circuit, when it detects voltage below a certain level, it disable dc-dc converter through its enable input. A series transistor can also switch off power to dc-dc converter.
TL431 Battery Voltage Monitor - Storage
In this circuit disconnect R3 from +ve and connect to base of series pnp transistor to disconnect 12v supplying to converter circuit.
  • batt monitor.pdf
  • battery discharge protector.pdf
You mean that i should connect the base of a transistor in Ve and the emitter to the cathod of LM431 ? and the collector to the input ?
