Should I use ground plate to attach arrays of horn antenna?
ping-pong
Member level 2
Member level 2
Arrays of horn antenna
Can somebody tell me if I wanted to use horn antennas in arrays than should I use a ground plate to attach all of them on this plate. What should be the distance between the two pyramidal horn antenna to avoid any kind of interference which results in the reduce of gain or effects of diffracting lobes takes place. Waiting an early reply.
