cyberblak
Full Member level 2
Hi all,
I need to design a signal amplificator with the following specs :
input signal : 0mV - 100mV
output signal : 0mV - 3V (not inverted)
The input signal comes from a shunt resistor that monitors a current.
I know how to do this, but I have the following constraints :
- use only 1 opamp
- no negative supply (the amp should be single supply)
- 0 should be a true zero (most rail to rail opamps still can't go to 0)
Any ideas?
I thought of adding a small bias to the input signal so that the output wouldn't need to go to zero (this is the main issue right now). I can remove this offset by software later. Is it a good idea and how to do this?
Thanks all
cyberblak
- use only 1 opamp
Any ideas?
Thanks all
cyberblak
