Short range fm transceiver
sokrat
Full Member level 5
Full Member level 5
EGYPT
Hi all
I need simple circuit for Short range fm transceiver " around 5 meters"
S 8O KRAT
House_Cat said:
Have you considered a single chip transceiver? One manufactuer's data with a schematic can be found at:
h**p://www.metatech.com.hk/datasheet/himark/transceiver/TR5100.pdf
You could also combine a simple FM transmitter, such as one found at:
h**p://www.discovercircuits.com/R/rftrans.htm
With a simple FM reciever, such as found at:
h**p://www.discovercircuits.com/R/rec-circuits.htm
You will have to adjust the tuned circuit values for your specific frequency desires.
The application circuit for this single chip is very complex compare than two individual circuits :cry:
S 8O KRAT
