kushal nandanwar
Full Member level 3
- Joined
- Jun 9, 2013
- Messages
- 177
- Helped
- 6
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 18
- Activity points
- 1,258
A simple current-limit design uses two BJTs, but that requires about a 0.25Ω resistor in series with the power to the bridge.
If that's too large a resistor, then you need to go with a more complex circuit such as the comparator and transistor that d123 suggested.
What's your preference?
Hi Kushal,
If you mean at the power rail input to the bridge - just an idea, might not work or be suitable - how about using an op amp as an error amplifier driving a low rdson p channel as a high side gate (if that's how you say it) or a power BJT, using a very low value sense resistor in series with the MOSFET/BJT output/input to the bridge. Good and bad is that a 5 milliohm sense resistor only drops 15mV.
Could include a shutdown at or over 3A using a comparator instead of the error amplifier idea, but that senses something more sensible than 15mV, maybe using a 0.5 ohm sense resistor - but that would drop 1.5V and waste 4.5 Watts. If you use a 0.010 or a 0.005 sense resistor, or better a 100 milliohm (0.9 Watts and 300mV dropped) and amplify that voltage into a comparator.
I'd go with the PNP BJT version myself, as it's all I'd know how to try to make, driven by an NPN small BJT as I'd find it easier to implement regarding the op amp error amplifier controlling the current at 3A (hopefully), and you could still add a comparator to shutdown the line in over current situation using another NPN out of the comparator driving a PNP which could be used to pull the H-Bridge PNP gate low (i.e. high) - maybe?
Maybe hard to put together: a comparator that detects 3A and instead of shutting down triggers an error amplifier to limit current to the 3A value - not sure how to put that idea into practice without a lot of thinking, sorry.
Look for
* current sense amplifiers,
* shunt monitors
Klaus
The polarity on the PNP is incorrect for it to conduct (base and emitter need to be reversed) but, even if it did, with that value of shunt resistance the minimum short circuit current is about 175A(!) since the transistor requires about 0.7V Vbe to turn on.
For a 3A limit the sense resistor needs to be about 0.25
voltage drop varies 0-60 mV.
Means every mV represents about 50mA.while I turn the power supply from 0 to 3.5 A.
I'm puzzled as to how it can work.
As the current increases the emitter voltage becomes more negative (less positive) when tends to shut the transistor off.
Or is that what you intended, that the transistor is normally ON and turns off as the current increases.
If so, that circuit will be very sensitive to the base-emitter voltage and any change in temperature.
Expect a change in current reading of about 100mA every °C temperature change of the bjt.
Klaus
