Short channel effect on Threshold Voltage of a MOSFET.
iVenky
Advanced Member level 2
College Station, Texas
In a short channel MOSFET the source-drain charge increases when compared to the channel charge (in the static conditions). So what will happen to the threshold voltage? Will it increase or decrease?
in short channel effect the threshold voltage increases
In short channel MOSFETs threshold voltage decreases. This effect is called Drain Induced Barrier Lowering
http://www.cs.ucl.ac.uk/staff/ucacdxq/projects/vlsi/report.pdf
thank you for your help
---------- Post added at 12:27 ---------- Previous post was at 12:26 ----------
In short channel MOSFETs threshold voltage decreases. This is correct.
Who is correct?
Both probably. In the 180nm process I'm working in now the Vt increases for shorter channels. I seem to remember a process where Vt went down as channels got shorter but can't say for sure... it seemed like it went down for one MOS type and up for the other.
DIBL is a lowering of Vt with an increase in drain voltage. Its effect is greater in shorter channel devices, but Vt is a function of length even without DIBL.
