shielding SMPS- must the shield enclose entire circuitry?
eem2am
Banned
shielding an SMPS
Hello,
If an SMPS is to be shielded to prevent it from radiating to the environment…..
-then is it true that the shield must enclose the entire SMPS circuitry, or else the radiation will simply be emitted by diffraction out of any gaps in the shield?
shielding an SMPS
There's a parameter named wavelength.
Re: shielding an SMPS
Yes your are correct. Apetures on the SMPS walls ( for signal cabling and ventilation) are the raditation coupling paths. Aperture will resonate at half the wavelength, and it will start allowing the EMI from that frequency.
Shielding should be grounded well.
