neazoi
Advanced Member level 6
Hello,
These two chips use the same frequency crystal for their internal oscillators (3.5795MHz)
1. Will there be a difference if I use a 3.8MHz crystal instead, with the same results, or is the frequency that critical?
2. Can the TP5088 share the same crystal with the 74hc943, since they operate at the same crystal frequency?
How can this be achieved?
I can see that both use a gate (although one is inverted) for the oscillator. So maybe I can somehow get the output of the internal oscillator in one chip and drive the input gate of the second?
Thank you
Thank you
