2 months before i bought the battery....voltage drops down
I dont think your battery is ok and moreover your battery doesn't supposed to go down up to 7 volt at least 10.6volt it shut down the system, otherwise your battery will not last even if its in good condition...
It depend on how you set up the battery cutoff,normally we set it at 10.6v then is shut down the system so if your inverter doesn't have control over low battery then your inverter will keep working even the battery is below 10.6v which will effect the life span of your battery also.Yes, the battery if it is good should not fall below 10.6V.
