dpaul
Advanced Member level 5
Having worked only on hardware designs, I am completely new to the development and functioning of toolchains. Hence I need help.
Situation: I am having a MIPS32 uP (h/w custom designed) which has been tested on Altera FPGA. I now want to develop/create toolchain specific for this MIPS uP such that I can run test-cases developed in C on bare-metal target (no OS support). After some internet search I found out that "Code Sourcery Lite" has MIPS support. Hence I have installed "Sourcery CodeBench Lite 2014.11-21 for MIPS ELF" on my Windows machine (because I want to generate an ELF file from the source C code that can run on bare-metal/Altera-FPGA).
Need: I have briefly gone through the documentation 'getting-started.pdf' that comes with Sourcery CodeBench Lite but I would still need a starting point or guidance.
Can someone briefly point out the steps I should follow in order to build/customize a toolchain from the Code Sourcery resources available such that I can generate an ELF/binary for my target MIPS h/w from a C code?
How do I setup this cross-compilation tool-chain?
Looking fwd...
dpaul
Looking fwd...
dpaul
