This next question concerns again the vicor power modules, please may i therefore put it here?...
We are doing a 48vin to 1V5, 95A power supply using a PRM module (48v to 48v) feeding into a “electronic transformer” module (VTM module).
Module datasheets are below.
We don’t want the VTM module to turn on when its Vin is less than 40V….therefore, can we leave its VC pin unconnected?
Also, we are using the PRM module in “adaptive loop” mode. So does the temperature compensation aspect of this come from the TM pin of the VTM module?...or does it also come from the VC pin of the VTM module?.........the VTM datasheet on page 3 says that the VC pin internal resistance is used in “adaptive loop” mode…..but if that’s the case then what does the TM pin do?
PRM48BH480x250A00 datasheet
http://cdn.vicorpower.com/documents/datasheets/PRM48BH480T250A00_ds.pdf
VTM48EF015T115A00 datasheet
http://cdn.vicorpower.com/documents/datasheets/VTM48E_015_115A00.pdf
Hello, The following question concerns the same power modules as in the above questions, so may I place it here?...............
We want to increase the soft start time. Can we do this by adding an external capacitor to the PC pin? -Or does that just increase the start-up delay time?
