nrf
Junior Member level 1
Hello,
I would like to simulate a schematic several times, with the "section" of the model library file as a variable.
Basically, on the Analog Design Environment, under setup->model libraries I select the model I want to use and its section. My model has got a lot of sections I would like to simulate, so I was wondering if maybe with OCEAN I can specify the section as a variable and then vary that through all the strings values the variable can have, as I was running a parametric analysys.
Thanks for your help.
