FreshmanNewbie
Advanced Member level 1
I have this MAX9278 GMSL1 Deserializer.
I have 3 below questions:
Vertical Resolution = 800 Pixels
Horizontal Resolution = 480 Pixels
Frames Per Second = 60fps
Blanking Percentage = 20%
Approximate PCLK = (800 * 480 * 60 * 120%) / 1000000 = 27.648MHz
Is the above calculation for PCLK correct? What would be a good value to set for my above TFT? And there is no provision to connect external crystal to the deserializer?
- How to configure the CX/TP pin if I want to use the coax mode?
- And how to arrive at the address of the deserializer if I connect both ADD0 and ADD1 as ground? I am not able to understand the table 10.
- I have 800 * 480 TFT 3.1 inch.
