Setting Rules in Altium to restrict layers to certain components
mauro1612
Newbie level 3
Newbie level 3
Hello, I'm new in this comunity and I need some help.
I want to set a rule to avoid the autorouting using the top layer in some components.
I've tried with the querys:
InComponent('U1')
and
InComponentClass('Bottom')
But neither of them worked.
Any suggestion?
Thx a lot.
welcome,
you should write like this = ( (InComponent('U1') ) and (InComponentClass('Bottom')) )
regards.
Thanks Zula.
I'm sorry I wasn't clear enough. Those were two different attemps.
U1 is already included in Bottom class.
Just in case, I tried your suggestion but it didn't work.
---------- Post added at 15:50 ---------- Previous post was at 15:50 ----------
Let me show you with a picture what is my problem:
Here is a picture of U1 autorouted. I want to only reach U1's pads with bottom layer tracks. Am I clear?
---------- Post added at 16:40 ---------- Previous post was at 15:50 ----------
Update:
I've also tried setting a Pad Class.
Here's how I built the query:
And here's how I defined the class: (all the pads of U1)
Altium is just ignoring my rules. Any suggestion is welcomed. I need to finish this work today, if possible.
Thanks a lot.
ok. iam understand your problem and solved. firsly you have to create a room around the U1. then double click on room and change the layer status to 'bottom layer'.
finally autoroute->room, select the room.
İ have tried and its okey.
regards.
regards.
Thx a lot but it didn't work for me. It didn't route at all.
I'm using Altium Designer Summer 09.
Any other suggestion?
i have to ask you last question. Can you route it at all manually??
Yes, without any problem.
---------- Post added at 22:01 ---------- Previous post was at 21:24 ----------
If I set it to route the net 'GND' only in bottom layer, it works properly. I'm confused.
