Setting one variable in PicBasic string
gzorzi
Junior Member level 1
If I want to set one variable with this string "picbasicpro2.34 setup"
Can I do ?
Thanks
picbasic string compare
PICBasic doesn't provide string handling capabilities, strings can only be used with some commands.
But you can :
- create variable arrays
- use the directive #DEFINE (inline asm)
string picbasic
If I use
a var byte[20]
Can I put a string in a variable on 1 step ?
example a="derftgyhuju" ? I think no
Can I do it ?
I don't know #DEFINE directive
can you write me example ?
Thanks
pbp string handling
Hi Gzorzi, please take a look at:
I have an answer for you, can you try and let me know if it works?
Tornado
picbasic string arrays
hi
your example
a var byte[20]
a="derftgyhuju"
is not permitted with PbP :cry:
other compilers like MBasic pro allow this :?
you can use the #define directive only in inline asm, its a little more complicated
but if you use string array in built-in functions that get strings like serin you can use the PbP 'STR' modifier
working with string in picbasic
I don't know MBasic but do MBasic use ICD how microcode studio plus ?
