toninlg
Member level 1
![Member level 1](/styles/images/ranks/dlevel1.gif)
I would like to set a default value for a signal or a port in VHDL.
For signal I've seen a post speaking about some solutions:
1) process without activity list and a wait; (wait without until) but Quartus wan't a until after the wait statement.
2) if (now < 1ps). Does it works in hardware or only in simulation? I don't know how to use it in my code, because I already update the signal in a process. So I've got an error if I use it outside of the following process.
What could be the solution? Is there a mean to execute a processus or a part of a process only at power-up or reset?
I've seen that Quartus supports initialization at declaration but not for all FPGA.
PROCESS (INT)
BEGIN
IF (INT'EVENT AND INT='0') THEN
scmpr <= data (6 downto 0);
sens <= data(7);
END IF;
END PROCESS;
