setenv PATH /home/EDA/bin:$PATH is ....
yesme@
Member level 1
Member level 1
I want to set path in Cygwin (Linux-like) environment such as we do in UNIX/LINUX as follows:
In Cygwin, what do we do ?
tks,
tks,
Hi
If you see a '$' at your prompt you probably are in 'sh' or 'bash'
In this case use
...$PATH=$PATH:/home/EDA/bin
...$export PATH
or put these two lines in your local .bashrc file
If you see a '%' at your prompt you probably are in 'csh'
In this case use
...%setenv PATH= ${PATH}:/home/EDA/bin
or put these two lines in your local .cshrc file
tnx
