imranahmed
Advanced Member level 3
- Joined
- Dec 4, 2011
- Messages
- 817
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Karachi,Pakistan
- Activity points
- 6,493
Please let me know I connected a LDR to Arduino UNO at pin A0 analog pin and Arduino UNO`s sleep and wake instructions are programmed. But only external interrupt is available for wake up of microcontroller cpu. I want to wake up microcontroller at a certain voltage level defined by me. Do we set external interrupt voltage to trigger at pre-defined level?
Full working code is below but voltage level to trigger external interrupt at pin2 is want to know?
#include <avr/sleep.h>
#define interruptPin 2
unsigned long lastTimeOut = 0;
unsigned long timeOut = 5000;
const int LDR_PIN = A0;
void Sleep(){
sleep_enable(); // Enable sleep mode
attachInterrupt(0,wakeUp, LOW); //Attach interrupt to pin 2
set_sleep_mode(SLEEP_MODE_PWR_DOWN);//Full Sleep mode
delay(1000);
digitalWrite(LED_BUILTIN, LOW);// LED OFF
//delay(1000);
sleep_cpu();
Serial.println("Just Woke Up");
digitalWrite(LED_BUILTIN, HIGH);// LED ON
void setup() {
Serial.begin(9600);
pinMode(interruptPin, INPUT_PULLUP);
pinMode(LDR_PIN, INPUT);
pinMode(LED_BUILTIN, OUTPUT);
lastTimeOut = millis();
void loop() {
int ldr = analogRead(A0);
int v = (5*ldr)/1023;
Serial.println(v);
if((millis() - lastTimeOut) > timeOut){
Sleep();
// delay(1000);
void wakeUp(){
Serial.println("Interrupt Fired");// message to serial port
sleep_disable();// Disable sleep mode
detachInterrupt(0);// remove interrupt from pin 2
