mult
Junior Member level 1
Hello there.
If PVS DRC/LVS rule deck uses variables (path to command files folder, metal option, etc. ) then is it possible to set/modify/store them within Cadence PVS environment?
Just like we can set and store such variables in a runset file with Mentor Calibre Interactive (Setup->Set Environment Variables).
I found the only way how to set/modify variables to be used by PVS rule deck: SKILL command setShellEnvVar("variable_name=variable_value").
But I would like to know how to store them, shall we say, in a preset or config file to be used by the tool to get rule deck variables?
Thank you!
Thank you!
