Servo control with microcontroller
Rohith_elec
Full Member level 4
Full Member level 4
I have a DMES8G-03, but i dont know how to control it, it is continous rotation type and is used in photocopier,
below is the pic, anybody have an idea ?
four wires
2yellow , 1red and 1black
one yellow wire is isolated from other wires
The black should be ground while red is +V.
The other wires must have something to do with the feedback circuit.
I searched the Internet for this model number and found this post :
The author says that the servo uses a "magnetic revolution pick up" sensor on the shaft.
Please try to find some info about it.
I can asure you, that a microcontroller won't be enough to make it work.
You'll need a power stage circuit also.
Yes.
A single PWM controlled MOSFET for rotation in one direction or an H bridge if you want to make it spin in 2 directions.
