servo based dual axis solar tracker
Jestin_cubetech
Advanced Member level 1
2 servo motor
4 LDR
PIC16F877A
hi
i try to make this project ,the mechanical constraction i completed but,i have some problem about software ccs c code, i desire from you the codes in 16f877a .please help me .
thanks
https://www.instructables.com/id/Arduino-Solar-Tracker/
#include <Servo.h> // include Servo library
Servo horizontal; // horizontal servo
int servoh = 90; // stand horizontal servo
Servo vertical; // vertical servo
int servov = 90; // stand vertical servo
// LDR pin connections
// name = analogpin;
int ldrlt = 0; //LDR top left
int ldrrt = 1; //LDR top rigt
int ldrld = 2; //LDR down left
int ldrrd = 3; //ldr down rigt
void setup()
  Serial.begin(9600);
// servo connections
// name.attacht(pin);
  horizontal.attach(9);
  vertical.attach(10);
void loop()
  int lt = analogRead(ldrlt); // top left
  int rt = analogRead(ldrrt); // top right
  int ld = analogRead(ldrld); // down left
  int rd = analogRead(ldrrd); // down rigt
  int dtime = analogRead(4)/20; // read potentiometers
int tol = analogRead(5)/4;
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr;// check the diffirence og left and rigt
if (-1*tol > dvert || dvert > tol) // check if the diffirence is in the tolerance else change vertical angle
if (avt > avd)
servov = ++servov;
if (servov > 180)
servov = 180;
else if (avt < avd)
servov= --servov;
if (servov < 0)
servov = 0;
vertical.write(servov);
if (-1*tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
if (avl > avr)
servoh = --servoh;
if (servoh < 0)
servoh = 0;
else if (avl < avr)
servoh = ++servoh;
if (servoh > 180)
servoh = 180;
else if (avl == avr)
// nothing
horizontal.write(servoh);
delay(dtime);
thank you very much for help
