Callemanbager
Newbie
Hello!
Disclaimer - i basically have NO understanding of electronics, just the crazy basic stuff.
I recently got an idea that i wanted to have an old car headlight on my old bicycle so it would look like a motorcycle. So i bought an old car light!
now the problem is how i will get it to work. Here in sweden, almost all old bicycles have ”dynamos” which are essentially just small 6-volt generators that you flick in so that they roll on the side of the tire - and then are able to power a 6volt light. (Maybe ”dynamos” are common elsewhere too, i have no idea). I want to power my car light with ”dynamo-power” so that i wont need any batteries.
of course the headlight is 12 volts, so powering it with one dynamo didn’t work (i found out the hard way)
but i asked one of my teachers who seems like he has some kind of idea of how stuff like this works, and he told me that if i series-connect two of these dynamos (so plus from one and minus from the other and then connect the two remaining poles to eachother) that it should make a 12 volt signal!
I tried it today and there was no light in the headlight. I did tape some cables together, so maybe that was why it didn’t work.
should it work???
(I have tried the headlight with a car battery so it does work.)
should it work???
