Hello ssparks,
DC-Motors don't have series capacitors, only parallel.
The "parallel capacitors" will be chokes, because capacitors will not let pass DC.
In combination of the chokes and the capacitors it will be a network circuit against interference in your radio.
If the motor not works, my experience says, that the fault is inside the motor in the control circuit, but not in the network.
Can you measure the voltage between the connections of the motor. If the voltage is present, your motor is broken.
Regards
Rainer
I think you meant the "series capacitor" will be a choke.The "parallel capacitors" will be chokes, because capacitors will not let pass DC.
