// Return values:
// DHTLIB_OK 0 => OK
// DHTLIB_ERROR_CHECKSUM -1 => Checksum error
// DHTLIB_ERROR_TIMEOUT -2 => Timeout
int read(int pin)
uint8_t bits[5]; // BUFFER TO RECEIVE
uint8_t cnt = 7; // bit counter 0..7
uint8_t idx = 0; // buffer index
// EMPTY BUFFER
for (int i=0; i<5; i++) bits[i] = 0;
// REQUEST SAMPLE
pinMode(pin, OUTPUT); // set pin for output
digitalWrite(pin, LOW); // write '0'
delay(18); // delay 18ms
digitalWrite(pin, HIGH); // write '1'
delayMicroseconds(40); // delay 40 microseconds
pinMode(pin, INPUT); // set pin for input
// ACKNOWLEDGE or TIMEOUT
unsigned int loopCnt = 10000;
while(digitalRead(pin) == LOW)
if (loopCnt-- == 0) return DHTLIB_ERROR_TIMEOUT;
loopCnt = 10000;
while(digitalRead(pin) == HIGH)
// READ OUTPUT - 40 BITS => 5 BYTES or TIMEOUT
for (int i=0; i<40; i++)
loopCnt = 10000;
unsigned long t = micros(); // this function returns the timestamp in microseconds
loopCnt = 10000;
if ((micros() - t) > 40) bits[idx] |= (1 << cnt);
if (cnt == 0) // next byte?
cnt = 7; // restart at MSB
idx++; // next byte!
else cnt--;
// WRITE TO RIGHT VARS
// as bits[1] and bits[3] are allways zero they are omitted in formulas.
humidity = bits[0];
temperature = bits[2];
uint8_t sum = bits[0] + bits[2];
if (bits[4] != sum) return DHTLIB_ERROR_CHECKSUM;
return DHTLIB_OK;
