Serial port program using vc++
hmsheng
Full Member level 4
Full Member level 4
China
How to to send data from COM without start&stop bit use VC++ progremming?
The data has to contain the startstop bits, so the interface can know when begins the data transfer.
An easy mode to overcome is by using hyper terminal. There you cen set the communication protocol.
Check first that, if your win can do that.
This is code for serial port in dos-mode using vc++
