Serial data transfer in c++
silver
Newbie level 5
Newbie level 5
Can some one explain me
how can program serial port with c++
thanks
Hi......
U can send data to serial port using "outportb" command......
I have done it in Turbo C++ compiler.........
I am also attatching a file with the title Interfacing the serial / Rs 232 port....it contains all the info one needs to know about serial port data transfer.....also contains C++ codes for doing so.....Hope that this solves ur problem :)
for proper syntax open turbo C compiler and find outportb in help.....
hi, silver
Search google for 'Ramon de Klein cserial'. I used his serial class with good results.
serial communication is very easy, because you don't need any driver just use readfile, writefile.
you simply use the Windows API if you programming in Windos.
IF you search in google you can find many links and examples to serial port programming.
Bye.
Hi guys
First of all thanks for your attention
Are there any componet for rs232 communication for Borland C++ Builder
Thanks
Hi guys
Thanks 8O
you can use a active-x like mscomm from msdn library...
Yes there are many, go to Delphi Superpages.
I prefer to use google to find it.
Anyway, there is "async32", what good enough to deal with.
You can use it very easly.
A common way to do serial transfer from a windows program is to use the Win32 API.
Essentially you: use CreateFile() to obtain a handle to the serial port, then you use a DCB structure (https://msdn.microsoft.com/library/en-us/devio/base/dcb_str.asp) to set the baud rate, etc.
This method will work even under Windows 95. It is probably also the quickest way to do it as it doesn't require any intermediate DLL, ActiveX control, etc to do it.
- Jayson
