SERIAL DATA EMULATOR/Serial data generator
arunkollam
Junior Member level 2
Hi
Any have a software which can generate serial data sequence or ASCi charactors through the output ports(USB/SERAIL) of a pc.
Thanks in advance
Arun8-O
use hyper terminal and select port and type what you want.. If you need need it faster means Put a file on it....
Hi
I have hyper terminal, but i need a software which sends data continuously which is preprogrammed.for example if i need a continious sequence0x01 at port 2.an example of such a software is **broken link removed** need something different.my purpose is to send a sequence of data to a UART, which process the data.
Thanks
Arun
