Serial Communication
10NAthan
Newbie level 2
Newbie level 2
How to communicate At89s52 and Pic16F73 ...
Send the queries i've found problem reg this....
Both those chips have hardware serial Usarts so it should be easy to communicate either chip to chip or via Max232s if more than a metre apart.
if you have the sample code means post here i've found problems with this module
Thanks for your valuable reply.
You do not mention anything about the compliers you are intending to use.
Sounds like you have little knowledge of either, correct ?
Trying to program 2 different micros from scratch is not an easy task; let alone talk to each other.
Are you using hardware or is it just a simulation exercise.
I cannot help you with the AT coding, if you search this forum you will find many examples of Pic16F serial / Usart coms.
