emontllo
Full Member level 4
Hello!
I am developing a system that requires wireless serial communication between 5 nodes using Bluetooth.
The system has one “Bluetooth master” and 4 “Bluetooth slaves”. Bidirectional serial communication must be established between the slave and the nodes. From a functional point of view, the system should be similar to a daisy chain connection RS-232 bus (i.e. the communication channel should be always ready for the slaves if the bus is free).
Is it possible to develop such structure using OEM Bluetooth modules? (I have been looking to Lair Technologies BTM411 and BlueGiga WT12-A-AI) Any recommendation?
Is there any limitation when interfacing various nodes with serial communications?
Thank you for your responses!
