serial comm issue when reading sensors...
kievari
Member level 2
Member level 2
I have a configuration consisting of:
1. my Atmega168 MCU connected to some servo motors and sensors, and
2. my Linksys WRT54GL router working under OpenWRT Linux WhiteRussian 9.
3. they have a working and tested serial connection.
Now my problem.
I open a file descriptor to my serial port called /dev/tts/1, and read a sensor (the second
sensor commented, as you see bellow). This works perfect. Then I uncomment the next
sensor, but the code continues to behave as if I didn't uncomment it!
If before the reading of the next sensor I first close my original file descriptor and reopen it, it
starts to work right, but this is inefficient, as I have various sensors and it is not logical to open
and close port for each of them!
Reading Ultrasonic first, and then Digital encoders or vice versa makes no difference.
The code in my MCU is fairly simple and tested. It does nothing but read/write as Linux
commands.
How can I approach to reveal where the problem is?
Linux code:
//motorController opens "/dev/tts/1" serial port.
   bzero(buffer,256);
   while(1==1)
     fprintf(motorController, "@sp\n" ); //s:sensor, p:ping.
     fscanf(motorController, "%s", buffer);
     printf("Ping: %s\n", buffer);
     bzero(buffer,256);
     fprintf(motorController, "@sel\n" ); //e: encoder, l:left.
     printf("Left Encoder: %s\n", buffer);
     bzero(buffer,256);
   fclose(motorController);
   return 0;
Without knowing too much about what you are doing it sounds
to me as if your file system is caching your code.
Look for a means of flushing the cache associated with the file handle
or - if my idea is correct - you will have to close and re-open as you are
doing - or finally - find a way to prevent your system caching your files (probably not the best solution - use No.1 if you can)
jack
