Serial Com Port -> DAC
gvanto
Member level 1
Member level 1
I would like to, using Matlab preferably (but something else like C++ might be good too), to output a digital number (not sure how many bits) to my PC's serial port (or USB if possible?) and then use an digital-to-analogue converter to convert the signal into analogue form.
Its for a small research project.
I have no idea where to even start. I am pretty sure Matlab can output stuff on the coms port but not how to. Also we have a limited budget not millions :D
Advice much appreciated!
gvanto
If your software supports ActiveX controls you can use MSCOMM, Microsoft's controller for the serial port. You will need mscomm32.ocx
You can get it from this URL
There is also a good description of the control here.
Next you need to register it. From the Start button and then run, enter
regsvr32 mscomm32.ocx
Registration unfortunately is normally not enough. Access this URL an
follow the directions
Once this is done you will be able to access the MSComm control in an
application that uses Active X controls like Excel Word, as well as Visual Basic itself. You may need to add it to the controls within your application.
All this (including a full description on the MSCOMM control) and much more is covered in my book
"Excel by Example : A Microsoft Excel Cookbook for Electronics Engineers"
Published by Elsevier/Newnes, ISBN 0750677562 (you can see the TOC etc. on
Amazon)
Hope this helps
Aubrey Kagan
    gvanto
Kool thanks but I'D like to do this using Dev-Cpp...it doesnt allow ActiveX controls - anyone perhaps know how to communicate with serial port?
thanks for help,
gvanto
MATLAB has a serial port object that you can use to output data to your PC's serial port. You may then use a microcntroller to receive the data and output it to a port to be fed to a DAC like the DAC0808
Good luck
