Serenade SV- Error \\\ ==> Undefined label: 0POR.Divi
robertka
Newbie level 1
Newbie level 1
There is a small problem I have encountered trying to learn Serande SV 8.5.
Having no experience in SPICE, I have made a simple voltage divider, just DC
source and 2 resistors. I clicked on “Analyse” but it failed and there was an error message:
\\\ ==> Undefined label: 0POR.Divider: 0POR
What does it mean? I could not find anything in help files.
Any idea, please?
:cry:
Re: Serenade SV- Error \\\ ==> Undefined label: 0POR.
Serenade is not SPICE simulator but RF simulator.
Replace the voltage source with a microwave port
and then run an analysis. After that you can view
the frequency response of your circuit - view the
S parameter response, VSWR, Z, Y parameters ...
As your voltage divider is frequency independent
the responses will be straight lines.
Try to add some frequency dependent component e.g.
a capacitor, inductor, transmission line...
To have a quicker start open the examples directory
and simulate some projects from it. There are also
3-4 tutorials, but they are a bit complicated.
