moshik3
Member level 2
I used this calculator to calculate my needed inductor.
the thing is, it takes Vin max and Vin min,
and an absolute Vout.
I need to have a variable Vout as well.
The application is to charge a big output capacitor (3000 uF+) to 250-700 volts - variable. sometimes to 250, sometimes to 700, and sometimes in between,
the Vin rang is to accept 110vAC or 220vAC which gives when rectified about 150v min and 350v max.
my parameters would be:
Vin min 150v
Vin max 350v
Vout min 250v
Vout max 600-( even 700v)
I out (wanted) about 1A. average.
say 1.5A at 250v out and 0.8A at 700v out (if it is possible to vary, I would love to have a fixed input current, so the device always take about 500 Watts from mains, let's say)
My problem is
for Vout 250v it gives 2794uH
for Vout 700v it gives 1296uH
what inductor should i use ?
should i choose the biggest uH inductor ? the smaller ? or an average between ?
Also,
these values are huge, and coilcraft has maximum 1000uH coupled inductors to fit my needs,
i tried and put 3A in the max output current, then the value goes to ~400uH which is definitely easier to find.
the question is, what is the consequence if this current will not be met ?
I remind that we charge a big capacitor. at start i would need the maximum I out to charge the cap when empty, say 1A, but then it is charged and the current falls to nearly 0.
so can i take a smaller uH inductor (which means higher I out) but actually limit the current of the primary using a larger resistor, and thus preventing it to draw to much power from the mains ?
switching frequency will be max 30KHZ because i will use a 1200v IGBT that works at max 20KHz
any tips and hints would be highly appreciated !
Vin min 150v
Vin max 350v
Vout min 250v
My problem is
Also,
