arkaprava_b
Newbie level 1
![Newbie level 1](/styles/images/ranks/alevel1.gif)
Hi all,
I am trying to convert Sentaurus TCAD Inspect output data to use as an input file of ICCAP. I am working in HBT and need the forward gummel plot. I am using the version A-2007.12 of TCAD. From the Inspect manual i find the command to convert ,
load_library ise2iccap
iccap_Write fileName headerInfo DATA
headerinfo contains userinput, iccap input and output. when i run this command i get an error
as : can't read "data(0, ic)" variable is not array. But i had set ic and other variables using the command: set ic [proj_getDataSet "$file name" "collector TotalCurrent"]
I am confused what to do ,,,,,,,, pls help me to get the answer,,,,, may be it's too easy for u all,,,,,,
thanks in advance.......
