zawminoo
difference between sensor and transducer
Hi everybody,
I found the descrition of sensor, transducer and their different.
But there are two books say two different.
What is Right?
The first book say......
Transducers are the physical element which is a part of a sensor. A sensor is merely a sophisticated transducer in the sense that it contains some signal conditioning circuit capable of amplifying and refining the weak and raw signal that is available at the output of the transducer.
The second book say....
A sensor id defined as a device that is sensitive to motion, heat, light, pressure and other types of energy. A transducer is defined as a device that can receive one type of energy and convert it to another type of energy. This means that a transducer may include a sensor to include a sensor to sense the amount of pressure, and a circuit to convert the amount of pressure to an electrical signal.
I would like to know the true...
( transducer + signal conditioning circuit = sensor ) ????????
( sensor + signal conditioning circuit = transducer ) ????????
Thank
zawminoo
Hi everybody,
What is Right?
Thank
zawminoo
