marwafareed
Newbie level 6
Wish you all a nice day.
We need to send data from one transmitting board to two receiving boards, we are connecting them via Ethernet using TCP/IP protocol.
We connect the three boards as attached, but it was found that it is necessary to connect both the transmit and receive pins in the second receiving board to the receive and transmit pins in the transmitter.
Can we use the attached connection in case of UDP? ; (there is no need to connect the transmit & receive pins in the second receiving board to the transmit and receive pins in the transmitting board).
Kindly advice.
Thanks & Regards
Kindly advice.
Thanks & Regards
