mamech
Full Member level 3
Hello
I want to make an application in which I connect 2 distant micros using rs485. I intend to use max485 .I know that the output of micro is TTL. Will connecting micro directly to max485
will produce a 485 ? or should I convert the TTL to rs232 using max232, then connect its output to max485?
