Sending Data to Lcd using UART
noq23
Newbie level 1
Newbie level 1
cck
Hi, guys. I have problems regarding sending data to LCD through RS232. But I don't know whether my code is correct. I can't make it work with my code. I'm using a mikroC compiler. When I run it, the lcd did not successfully recevied the data.
My program:
char *i = "NNNNN" ;
void main() {
TRISB = 0x00;
Lcd_Init(&PORTB);
Lcd_Cmd(Lcd_CLEAR);
Lcd_Cmd(Lcd_CURSOR_OFF);
// Initialize USART module (8 bit, 2400 baud rate, no parity bit..)
Usart_Init(2400);
while(1) {
if (Usart_Data_Ready()) { // If data is received
i = Usart_Read(); // Read the received data
Usart_Write(i); // Send data via USART
Lcd_Out(1,1, i);
somebody please help me..:(
actually i have the same problem so if somebody knows how to fix it plz help
Reactions: wasio
    wasio
My program:
char *i = "NNNNN" ;
void main() {
TRISB = 0x00;
Lcd_Init(&PORTB);
Lcd_Cmd(Lcd_CLEAR);
Usart_Init(2400);
while(1) {
Lcd_Out(1,1, i);
i think if u write Lcd_chr(1,1,i) instead of Lcd_Out(1,1, i);
and check for 9600 baud rate once;
Reactions: wasio
    wasio
It sounds that you are reading from USART and not writing .
try this : while(1) { Usart_write(i) ; }
I'm have trouble understanding what you are attempting here?
Are you attempting to control and display text from a PC to a PIC with a LCD attached?
Or are you attempting to control and display text from a PIC to a Serial LCD?
IF the latter what is the actual make and model of your serial LCD?
BigDog
BigDog
solve
thanks
