Sending data from PC to FPGA via Ethernet
... Then how to distinguish the packet is coming from GEN component or from PC (netcat)??
Usually by inspecting the packet. Assuming you made your packets identifiable in some way. Anyways, I strongly suspect the answer will be "what design?" What question? This one: "Do you have an actual design you are trying to implement? Or are you just slapping networkey things together and see how it goes?" If you do have a plan, could you describe it?
I have specific/actual design. I am implementing following design:
The block diagram of major components of this design is in attachment.
on receiving side, UDP Port to Channel Mapper (UCM) component of this block diagram has following information:
Destination UDP Port = must match user programmed value (in verilog design code)
its corresponding c code for setting register say:
int map_udp_port_to_channel(void *base, alt_u32 channel, alt_u16 udp_port_number) {
    alt_u32 channel_reg;
    // is the channel already enabled?
    switch(channel) {
    case(0):
        channel_reg = UDP_PORT_MAPPER_RD_CHAN_0_PORT(base);
        break;
    case(1):
        channel_reg = UDP_PORT_MAPPER_RD_CHAN_1_PORT(base);
        break;
    case(2):
        channel_reg = UDP_PORT_MAPPER_RD_CHAN_2_PORT(base);
        break;
    case(3):
        channel_reg = UDP_PORT_MAPPER_RD_CHAN_3_PORT(base);
        break;
    default:
        return 1;
    if(channel_reg & UDP_PORT_MAPPER_CHAN_X_EN_MASK) {
        return 2;
    // not already enabled, then we enable it with the input port number
    channel_reg = udp_port_number & UDP_PORT_MAPPER_CHAN_X_PORT_MASK;
    channel_reg |= UDP_PORT_MAPPER_CHAN_X_EN_MASK;
    switch(channel) {
    case(0):
        UDP_PORT_MAPPER_WR_CHAN_0_PORT(base, channel_reg);
        break;
    case(1):
        UDP_PORT_MAPPER_WR_CHAN_1_PORT(base, channel_reg);
        break;
    case(2):
        UDP_PORT_MAPPER_WR_CHAN_2_PORT(base, channel_reg);
        break;
    case(3):
        UDP_PORT_MAPPER_WR_CHAN_3_PORT(base, channel_reg);
        break;
    default:
        return 1;
    return 0;
So, I guess if I set here in c code specific port number for UDP packet and assign it to one of the channel and then use this port number while sending packet from PC(netcat) to FPGA, then I might receive these packet (without header) at Avalon source interface of UDP payload Extractor (EXT) component of corresponding channel. Any suggestion please.
