I14R10
Full Member level 3
I designed a weather station. It will have main board with electronics for everything, and 4 wires that go to one small board with only temperature sensor. Wires are 3.3V, GND, SCL, SDA. Yes, I know I2C wasn't supposed to be used between two boards, and that it's only for a short distances. Yes, I will use it only for 20-ish cm.
But disregarding I2C thing, how stupid is it to send 3.3V with wires, from main board's voltage regulator to the sensor 20-30cm away? The sensor has a small capacitor by V_in pin.
