haytham said:semi custom : is to use already built modules instanciated from library into your design directly without making their own layout. Instead you will do the inteconnections betwen them.
Full custom : means that you are doning the work started from zero. No design no layout and you will do all the staff
I think the phrases semi-custom and full-custom for usage in analog and digital designs are correct. I didn't see a global library for analog cells until know but I beleive that every analog design team should have their own analog library at least for the basic analog blocks.
haytham said:Okay Omara
seems you are right. I mixed the two concepts some how.
Let me define it again
semi custom : is to use layout of already built standard cells into your layout. All what you need is to do the interconntion for theses cells.
Full custom : means to strat your layout from scratch and to build all your design layout by your self.
Am I right
Kindly correct me if you found something wrong here.
Thanks
Haytham
turtlynn said:is semi-custom the same as standard cells?
anyone know what is the difference between full custom and standard cells design flow?
Added after 3 minutes:
Hi can anyone help me solve this questions?
MyChip Enterprises is seeking my teams' advice as to how best to implement their new product into an microchip. They have these questions:
1) What design methodologies should they use?
2) Would the design using either Full Custom or Standard Cells Design Flow. Compare and contrast these different design approaches?
3) They would like to use to choose a design flow that supports the design methodologies in (1). Recommend either the Full Custom or Standard Calls Design Flow. Explain how your recommendation is consistent with the design methodologies in (1).
gbaerf said:so I can tell that FPGA based flow is semi-customed flow.
