Selection problem in altium
savage67
Member level 1
Member level 1
Hi Dears,
I am newbie in altium. My problem is to select the objects in a selected region. For example i use my mouse to select a region and i want to select only pads, tracks or components or texts etc in this selected region. is there a way to do this. as i remember, in pcad, there was a selection mask tool which organize the objects can be selected.
thanks and regards.
You can do it in following way press OD on your keyborad from window make all hidden and make pad as final now you will see only pad in the boards rest all will be hidden so you will be able to select pads only nothing else.
You can use PCB filter lso but I too is not very familiar with it you can have a try on that also
hi
on the PCB, u can select any pad or track what ever u want and then right click and use "find similar objects".
the other way is to set the rules or you can use the pcb filters.
hope this helps.
Regards
pcb inspector panel usage
additionaly there another way.
select the area then open the 'pcb inspector' panel. click the 'include only' from the panel then select the objects which you want to change(pads, tracks, etc...)
(see the picture)
regards Ali.
