FreshmanNewbie
Advanced Member level 1
I have a display whose backlight section has 7 LEDs in each of its 4 strings. So, total LEDs are 28. Typical and Maximum LED Driver voltge is 21.3V and 24V respectively.
The total current consumption of the backlight as mentioned in the datasheet is 200mA, typ.
My question is, whether this LED Driver would be suitable?
Asking this because, eventhough the above LED Driver satifies my current rating requirement, in the circuit application images on page 1 of the datasheet, only 1 string of LEDs is connected?
I am coming to a conclusion that this LED driver would be fine because I looked at the maximum switch current rating in the datasheet which is 500mA. Since, this is the peak current through the inductor, and this current is greater than my required LED string current of 200mA, I think this will work. Is my understanding correct? If not, how to verify? Also, does switch current parameter should be considered to arrive this conclusion?
What should I do if I have 4 strings? Can I short all the 4?
Just to clarify, that 200mA is a typical current for all the 4 strings, 28 LEDs together. I had heard that That is a fundamentally bad ideas because small differences in Vf can lead to big differences in the light output of the different strings. What are your thoughts on this?
