Selection of appropriate bus
wahabmalik
Junior Member level 3
Pak
Hi
I in intrested in using standard Bus based system like VME, CPCI, VXI etc. My intended application can easily be fullfil by an industrial PC or PC104 but we feel that we can get some exposure of Bus based system in this project. Some of my requiremts are
1. Intel Based System >1GHz
2. Should support Windows 2000
3. Data transfer rate is not very high. only external interface required are 2 Serial ports and 1 10BaseT Ethernet port
Moreover I've sufficent space available hence any form factor or dimension is suitlable.
Price and performance comparision is requisted.
If someone suggest me the appropriate system along with the manufature I will be much obliege.
Regards,
