mosfet01
Newbie level 3
I'd like to select the right DC DC converters and just want to make sure I am on the right track. The board will have 3.3V, 5V, 12V, and 24V supplies. My plan is to use a 24V supply and then step it down to 12V then down to 5V then down to 3.3V. The specs I usually look at is the output wattage first and then look at efficiency and so on. But my main concern is the wattage and whether I am making the right assumptions when selecting the right amount of output power. From my understanding of power calculation theory, if I have a load that draws 1A at 5V, then my 24V supply will draw 0.208A. I found that value by calculating the power absorbed by the load (5V*1A = 5W), then calculated the current sourced from the 24V (5W/24V = .208A). I'm assuming that if 5W of power is absorbed by the load, then 5W would be delivered by the 24V source. Am I making the right assumption?
